THOMAS'S WEB SITE
Date:  7-6-2016
Number of Hours:  6.00
Brief Description:  Installing the Turtledeck
After bonding the turtledeck to the fuselage the other day, there was still the need to reinforce the junction from the deck to the fuselage with fiberglass. The plan calls for BID 220 and 160 each side. Since I havn't had this combination, I used 163 and 286 with peel ply. Slightly stronger.
Before I got started though, I sanded and shaped the transition from deck to fuselage to make it smooth. Later I corrected two tiny dents with mico for the perfect underground.
For more details refer to the resin tables!
